It is currently Fri Aug 15, 2025 11:06 am
 Post subject: Delta Bandsaw (bs100)
PostPosted: Sat Oct 18, 2014 7:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I think it's 9 or 10" wheels. Little workhorse sets on my bench, endless uses. Today, while cutting coco segments in the Paulick Arch jig, it started misbehaving badly. I readjusted guides and bearings. No good, blade would just shift around on the NEW tires I installed a couple months ago. Finally, went and bought some new 59.5 inch blades and it settled down.
Really? I can't believe it was the blade. Am I wrong?
PostPosted: Sat Oct 18, 2014 7:24 pm
First name: Big
Last Name: Jim
Blades may have been misaligned when welded , would cause it to work back and forth
PostPosted: Sat Oct 18, 2014 7:42 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Well, I had been cutting arcs and perhaps I stressed the blade at some point. What u say makes sense. I took the old one off several times, reinstalled, adjusted bearings and guides and each time it started off ok then it would jump off center. I put the new one on and it was good from the start. So, I'm gonna slow those arc cuts down.
PostPosted: Sat Oct 18, 2014 8:00 pm
First name: Big
Last Name: Jim
What size blade. 3/16. 1/4. ?
PostPosted: Sat Oct 18, 2014 9:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
1/8". Need a small blade for that jig. I got through the final two rosettes, so it does appear the new blade was the fix.
PostPosted: Sun Oct 19, 2014 7:02 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Same blade, closeup:
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: Johny (Mon Oct 20, 2014 7:50 am)
PostPosted: Sun Oct 19, 2014 9:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Frank, yup, that's what it was doing. For grins, I went out and inspected the blade, could find no cracks. I guess I could put it under tension and see. This is a cheapie saw. If I could find a quality 9" bench model, I might be interested. They are so useful. Especially given they use those 1/8" blades.
PostPosted: Sun Oct 19, 2014 10:18 pm
First name: Frank
Last Name: Ford
City: Palo Alto
A badly welded blade will often do the same dance, as will one that has suffered a "crash" and has not broken, but become deformed.
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Sun Oct 19, 2014 10:53 pm
First name: Bruce
Last Name: Andrews
City: Terrace
State: BC
I see that lots on big band saws. When a blade has a crack it'll jump or get twitchy. I try to spot it right away and shut down before it snaps while cutting. Otherwise could be messy. Good sharp blades are awesome and make things so much easier.
High Mountain Tonewood Company
Bruce Andrews
Terrace, BC, Canada
http://www.highmountaintonewood.com
